I am fitting a Votronic MPP 360 solar controller in my van (Adria Coral Compact) to replace the Victron PWM Duo. It should give better low light performance.
I have a single 180 watt solar panel.
I have an Electroblock 262 + vop.
As per Votronic instructions I will run positive and negative charging wires from the mppt controller directly to the leisure battery terminals with the recommended fuse close to the battery. No problem so far.
The controller has a second charging port for trickle charging the starter battery using a 1.5 mm red cable direct to the starter battery positive terminal with an inline 5a fuse close to the battery. This works with reduced voltage and charging current rates, thus prioritising the leisure battery.
I have previously fitted an identical Votronic controller in our previous Adria Compact, wired in as above with no problems. The performance was fantastic in low light.
My question is this:
Can I connect my little red trickle charge cable from the mppt controller for the starter into the 'starter battery' connection on the rear of the Electroblock? because it would be so much easier than routing the little red wire all the way to the starter battery terminal? I don't know what size wire runs from the electroblock to the starter battery and whether it matters in this context but it would be so much easier than finding a route myself to the starter battery.
Hoping somebody understands this stuff and can offer advice,
thanks in anticipation, Mark.
