Vision Plus Tv 18.5 inch
Colchester, UK
Pilote G732
Total Newbie
So I’m looking at changing the Meos tv that was in the van when we bought it. It’s starting to get a bit temperamental and though not used a lot, it’s enough to be a pain.
A local retailer to us has a 2022 18.5inch ( which fits in the tv cupboard) Vision Plus tv for £260.
I’m looking at the spec and think it’s not too shabby.
Has anyone got first hand experience of this make of tv and if so, do you think they are good quality or would I be better off buying an Avtex?
We have that tv. It’s the 2015 model and although we don’t use it often, it has worked flawlessly. The only thing we’ve found is the sound. Not too good and quiet. Turn it up and it gets distorted. We’ve sorted that by using a sound bar attached to the bracket or Bluetoothing it to the Bose speaker.
I think ours is older judging by the condition of it!
The big plus point is that it fits in the tv cupboard out of the way unless you need it, any replacement would need to be able to fit in the cupboard as well.
We’ve got a Vision Plus 18.5”, probably 2017 model. OK, but tbh not a patch on Avtex ones we’ve had. In fairness it’s on a lift up frame, which probably puts extra pressure on connections, but both aerial input connections (coax and F type) have broken away.
Thank you for the input, I’ll have to explore the Avtex a bit more thoroughly.
