Victron Solar Controller (2 Viewers)
Jun 28, 2024
91
19
Leicestershire
Autotrail Apache 634
Since 1998
Just bought a Victron SmartSolar MPPT 75/15 controller. Does the little black jumper link need removing before I set it up via bluetooth?
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Just fitted the same model and didn’t alter the jumper just remember to connect the leisure battery first then the solar panel. Instructions are online 👍
Looks like it should be removed if you are using the app for settings. I'd be happier with it removed to be honest as it looks like something that will be easily knocked and is quite fragile
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Agreed fetching mine from storage tomorrow and I will remove. Thanks for the clarification đź‘Ť
Out of interest did you fit an inline fuse between the controller and the battery and if so what size fuse? I fitted one for the previously bought and utterly useless Dokio controller and used a 30A fuse (it was a 20A controller), but thinking this needs to be smaller now as the manual suggests 20A to 25A, but wondering if the 30A will still be of use?
Kannon Fodda
2,868
8,749
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
Any fuse should be the lowest rating possible to suit the wiring capability. If the connected appliance is lesser than the wiring, then fuse for the appliance i.e. solar controller. But fuse near battery for solar connection is always good idea.
I removed the jumper thing as I was using bluetooth.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
So the wiring I have is what came with the 160W solar panel (portable) and the now discarded Dokio 20A controller. I wanted the keep the wiring as it has XT60 connectors which I can use as a disconnection between battery and panel. How do I know what inline fuse suits the wiring in this case?
Jun 16, 2017
378
668
Bridlington
Mobilvetta Kea 80
Happy to help
Mine already had a 20amp battery fuse.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Just trying to set it up via the app but the preset battery options are confusing. We just have a standard leisure battery - flooded lead acid I believe, so what option would I pick?
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
Didn't you get to this part?
Yes but that is about the settings, I still don't know which battery type to choose from the options in the drop down list if that makes sense? I see others have asked the same question in that link though so once I have double checked the exact spec of my battery tomorrow I will also ask which to choose and what settings are best too. Thank you for the link
Apr 26, 2015
3,267
7,927
Ottershaw
Hymer S820
First motorhome May 2021
Sadly still no clearer as it just shows which to pick for a lithium battery so I may have to contact Victron
If you start changing values the battery type will change to user defined, assuming your batteries are 12v use the left most figures in Jev's post the other numbers are for 24v and 48v batteries, remember that temperature compensation is per cell so multiply by 6 for a 12v battery. Edit: Set battery type to gel and then start changing the values if necessary.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
But my battery isn’t gel as far as I know? I’m just trying to find where it states normal flooded lead acid battery but there is no option for that. Anyway I will ask on that link as others have and see where I get from there 👍
Lenny HB
55,886
163,073
On the coast in West Sussex
Carthago Compactline
Those wires are far to small to be fused at 30 amps you need to fit new cables.
Dec 2, 2019
3,877
8,560
Amersham
van conversion
Since 2019
Preset no 2, the values are for flooded batteries.
And ditch the wire on the battery side, to small.
Apr 26, 2015
3,267
7,927
Ottershaw
Hymer S820
It doesn't matter that your batteries are not gel because you're going to change the values to the ones you need for your battery, when you start changing the values the battery type will change automatically to user defined, it will no longer say gel. I say start with the gel preset because the values will be closest to lead acid, is that a bit clearer?
Apr 6, 2019
4,331
8,558
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
It lists the voltages for a 12v lead acid battery ..... Enter them manually as a custom setting.
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
I think I understand, thank you
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
It states on the back of the solar panel that they came with that they are 12AWG, but I ordered another XT60 connector from Ebay that has 12AWG cable attached and it is clearly much thicker. However, why does the cable need to be thicker as so many electrical items have wires this thin? If I drop the fuse to a 20amp one will that not resolve any concerns?
Pollypenny
Jun 28, 2024
91
19
Leicestershire
Since 1998
So the one that says 'Gel Victron deep discharge (2)'?
If I ditch the wire from controller to battery for thicker wire, do I also need to ditch it from the controller to the solar panel as that seems to be hardwired into the panel so not quite as simple to replace?
Tombola
5,198
16,647
Merseyside
Rapido 8094DF
Since 2004
Thank you but it is just the choice of battery I need to know to move forward before I can get to the change of settings section if that makes sense?
you can choose gel and edit it
