Victron Settings for KS Energy
York
Van Conversion
Newbie
Just had a KS Energy C210 lithium battery fitted, fed by a Victron Mppt solar controller and Victron Orion dc-dc (30a) charger. I've set both of these to the Lifepo4 setting but noticed that both of these carry on charging in bulk mode long after the battery bms shows 100% SOC. They eventually get to ABS mode but not sure if this is likely to cause a problem with overcharging. Anyone got anything similar ?
With LiFePO4 batteries If the Amps are still going in the battery is not full, the SOC figure may be a bit out of step but should synchronise with time. If the Amps have stopped flowing but the Voltage has remained at bulk charge level then the charger/solar controller settings are at fault. The LiFePO4 bulk charge phase should end when the tail current drops below a preset level, 2% of the battery capacity is the default setting on one of my devices.
A month on I hope you have already found your answers elsewhere, sorry I didn’t spot your post earlier.
I have has Lithium's for over a year now. When it reaches 100% SOC the batteries keep on charging Eventually going to Bulk then settling down to float.
One thing I have learned is that the SOC % is more of a guide and never totally accurate. After a good full charge I calibrate, but over time it becomes less accurate. I only now ever use the Voltage to get a more accurate reading.
Interesting, how do you use voltage of a lithium battery to gauge SOC?
Not possible to get an accurate state of charge with voltage.
The only proper way is by measuring current in & out with a shunt.
A lithium profile should go straight to off or the maintenance/float level when full. It is full when the current flow drops off which is easily detected by a properly set charger.
Thanks all. I had assumed that the SOC on the BMS was the oracle so to speak. I haven't used the van it for a while but will try driving for a while and see if the b2b eventually gets to float. I don't have a lithium mains charger but might be worth getting one I suppose.
