funflair
So a bit of a strange one today, it's actually sorted itself out now but still wondering what was going on,
Today I decided to have a look see how much solar I was getting as the sun was out, ZERO oops that can't be right, the app was showing -18 for battery temperature so that would be why, the Smart Battery Sense was reading 9 which would be right, on investigation the "Smart Solar controller" said it was getting the temperature from the shunt which as far as I know doesn't read temperature, I turned off the low temperature cut-off in the regulator and the solar came back up, messed about a bit with everything and it changed and the Solar said it was getting temperature from the "Smart Battery Sense"
This is after I switched off the low temperature cut-off.
This screen is showing the temperature coming from the Shunt.
Now it is right with the temperature coming from the smart Battery Sense.
So the basic question is why? and how do I rectify the issue if this happens again? other than just messing about.
