This page shows you what the panel is producing in this case 14.51v with no current in the "Solar" section, and in the "Battery" section what is going out from the controller again in this case the battery voltage (measured at the output terminal on the controller) and what current is flowing, some of which may go to loads like the fridge etc, and the remainder will be going to charge battery.Hi all, rather ignorant about this and hoping someone can please advise; can the Victron connect App show me what I am drawing from the battery/solar panel or just what the solar panel is ‘producing’?
Image taken in the evening so obviously panel is showing 0 W
The Victron Connect app can report on many things, depending on which Victron kit it is connected to. In your case, it's connected to the solar controller, so it is only giving the information that the solar controller has, which is the voltage & current produced by the panel & the battery voltage & charging current from the controller to the battery.Hi all, rather ignorant about this and hoping someone can please advise; can the Victron connect App show me what I am drawing from the battery/solar panel or just what the solar panel is ‘producing’?
