Victron bluetooth connectivity issue
it’s not new tech if my 7+ and old ipad 2 doesn’t work though is it 🤔🤣
i’ve just found this out btw 😉
You could try your old phone again or if someone has a Android phone/ table could download the connect app and see if device's are discoverable in Bluetooth remember you will need your old app log in details and password.
This would rule out the victron units
I had a look at victron community forum, and seen mixed results. Some successfully re connected after turning phone off few times and re pair. Some still in the dark. I hope victron picks on this and may tweak the next firmware. Some phones will not see the device on the Bluetooth, therefore no option to pair to.
Talk about going backwards lol
i’ve had no issues for 2 years with the Victron stuff but now they won’t or can’t be seen on any Apple device at all 😳
I’ve tried 2 7+ iPhones, 2 x IPad 2‘s with nothing at all, after doing what Ditcha said and cleared my bluetooth list on my 12pro the MPPT controller did show and said connected 👍👍, but then it instantly disappeared again 😭
SUCCESS!!!!!!!!!!
bloody hell it was simple as well
So every time I started the Victron app it asked me to input the default pin code which anyone having Victron stuff is 000000. I’ve never changed it btw😉 and i’ve been trying to connect for 3 days remember
So using the PUK code it allowed me to reset the pin code to default 000000, yes that’s correct, the same as it was 🤔
Anyway that’s instantly cured it and i’ve been able to connect to both items again
Result and all’s well in the world again 🤣
thanks everyone for trying to help but this is certainly worth remembering
Al 👍
So back to square one, I’ve had no issues since I worked it out last Sept until today and now i cannot connect to the Smartsolar controller again
The app is asking for this and I’m stuck again, i’ve tried the usual 6 zero’s but nothing happens
any ideas again peeps
First off, have you got your bluetooth enabled on your phone and if you have, does your controller show up in the list of paired devices ?
Bluetooth is on but Victron actually tells you to forget the device first before doing anything
I’ve another BIG issue now, my cab battery is down to 8.6 volts so I need a fiat Assist UK tel no.
Can anyone forward me that please and i’ll sort the Victron issue after this one lol
bloody hell i’m not having much luck am I 😱🤣
eddievanbitz
hi Eddie
just trying to get my head around this, Mick at SAP Doncaster fitted a Vanbitz battery master to this moho when it was brand new in Feb this year, if it’s faulty, and i hope it isn’t, could this be draining the cab battery do you know
thanks
Al
Edit:
the cab battery is now showing 5.8 volts 😢
