Wombles
Found out on Saturday that whilst the Meta Trak app shows that the Non Starter in our motorhome is armed, the engine still starts & may have been that way since we packed it away last October! Firstly hope this will act as a prompt for others to try turning the ignition on as a double check to what you see on the app. Couldn't get any assistance over the weekend but Meta Trak have checked what they can today so it seems to be a physical fault with the unit. As it'll be expensive to get this checked & a big bill for a replacement unit (it was fitted late 2018 so hadn't expected this) from VanBitz, Mr Wombles has just checked all the fuses following advice from them & no simple fix there. Thought it may be worth asking the Hive mind on here in case anyone has had the same experience & there may something else that we can check or a cheaper fix to consider?
