Yes yes campers.!
Second post and if its anything like as helpful as the first this will be well worth while. Im setting up my van as a moving music studio and its no secret that Speakers are not what you'd call energy efficient. This necessitates a pretty big power bank.
At the moment I've calculated the size of the system at absolute utopian usage levels - the thing will be totally self sustaining or 'off grid'. I am imagining the possibility of having speakers powered constantly for a whole 24 hours in order to see what is achievable. After that technological, space and economic factors will play a part in how big the final system is and what my usage is.
In the mean time I'm looking to find out some information with people who have a little bit of experience setting up a leisure battery system.
The first question is what type of battery - for many reasons it seems like lithium ion seems like a great option. Its expensive but the initial outlay seems worth it for some of the benefits [I know the lead acid/lithium argument is pretty loaded so I hope this thread doesnt turn into a lithium verse lead boxing match].
I'll be traveling from the coldest cold to the hottest hot so the performance in areas of varying temperature is a pretty crucial aspect of the batteries purpose - i understand lithium to be superior in this sense.
One thing Im uncertain about is the difference between a 'lead' amp hour and a lithium amp hour. Lithium sellers seem to suggest that a lithium amp hour is worth almost double that of a lead acid amp hour....Im well confused as to what that means practically though. Any info here would be great.!
With a lead acid setup I understand you have to pretty much double your amp hours so your battery does not discharge below 50% - with that I've calculated my utopian system size to be 3,200 A/h.
With a lithium battery I believe that means I would need a power bank of 1600A/h - but Im not sure given the problem above whether that means I need a Lithium system of 1600A/h or actually 800 A/h
There's a lot to read through there, but given the waffle above if anyone has any feedback, pointers or info on battery systems I'd love to know - Im also looking for company which supply great batteries so help in this direction would be much appreciated....I've found this which looks dope -
