Hi all. Just about to sort the electrics on my Citroen Relay L2 conversion, and looking for some advice on this... please chip in with ideas on any of the following!
I want to install the following: Lithium Battery, Mains Consumer unit, Renogy Dc/DC charger with MPPT, Inverter, DC fusebox. My conversion layout will be similar to Autotrail Vline 540, ie fridge +storage in tall cupboard behind drivers seat, with shower/loo behind that, and then rear seating/beds. Kitchen area next to sliding door on near side.
I was planning on installing the battery in the base of the tall unit behind the drivers seat, the fridge above that and then electrics mounted on the wall of the van above the fridge, which would accessible via a door in the back of the storage cupboard. See scruffy section pic below.
The idea is to keep the wiring runs as short as possible, have all the electrics in one place, and keep it accesssible. A charge/battery monitor will be mounted in a visible location somewhere at the front.
So my queries are:
1. Does this seem generally sensible? Switches, fuses etc will be accessed through a door at the rear of the cupboard, albeit at arms length.The entire top section of the cupboard above the fridge will be bolt mounted, so I can more easily install or upgrade components.
2. I think the regs say isolator etc has to be accessible - would this be considered sufficiently accessible?
3. Can I mount the electrics on a timber board? I'm pretty sure on my previous van the inverter manual said it had to be mounted on metal - -but might have mis-remembered.
4. Part of the idea is to mount the electric in a large void area (rather than completely enclosed) to assist in cooling. There will be vents in the van wall,. probably above and below as show. One concern here is that if some fool (probably me) jetwashed the exterior, the electrics would be soaked. I could mount the vents to one side, but that risk still remains. Are there any vents which are effectively waterproof, or some other method to ventilate? I could enclose the electrics but this would obviously prevent ventilation.
Grateful for any thoughts/input!,
Tom
So my queries are:
Tom
