Valves (1 Viewer)
Tillytuttut
17
4
Hitchin Herts
Avantgarde 400
I have
Peugeot Boxer attribute compass 2004.
The problem I have is reaching the valve for the water it's behind the fire, can it be moved to a more accessible position.
1i have had the motorhome home a couple of years but unfortunately was two ill to use it but I am making up for lost time this year .I love it
So if you can advise please
T
Tillytuttut
17
4
Hitchin Herts
Avantgarde 400
It empty fresh water out.But when I filled up after short while water ran out under van when filling so not to sure if open or closed
43,765
52,828
More likely the safety dump valve near the boiler.
Floor mounted valve with a yellow or possibly red lever.
Or is this what you mean? Stupid place to put it if so.
Apr 28, 2013
3,682
81,777
Alentejo,Portugal
Hymer A Class
Since the '80,s
If it’s the fresh water tank you are speaking about,generally if the tap is horizontal it is closed and if vertical it is open.Hope this helps,if not try maybe a picture or a little more info.Good luck.
Jul 6, 2016
1,547
1,265
West Sussex
Carthago Chic A clas
Since 1990
If you have a Truma boiler which heats the water and provides warm air heating, then the dump valve is probably mushroom shaped. Pull it up and it will be in the closed position. If it doesn't stay up, then the ambient temperature is too low ie. less than 8C. Warm up the compartment by putting the boiler on warm air mode. After say 15 minutes you should then be able to close the dump valve.
PS. If you have a gas fire and not warm air, then ignore the above.
TheBig1
Nov 27, 2011
17,851
44,358
there is a badly placed dump valve on our fresh water tank. i have bought an electrically controlled valve that i will fit under the van. then its as simple as pressing a button to empty the tank when needed
