V5 query
Bodkin40
Auto trail Mohican
I've already done a search but not found an answer to this, my v5 has no weight at all onit, it's taxed plg but the weight is 3850 which I guess will be taxed as phgv, does any 1 know if I just put it on to the v5 and send it off or is there more to it
Is it definitely the final VIN plate? I have two under the bonnet. The actual current one is randomly in the hab step alcove.
There are 2 under the bonnet side by side, the original 1 with weight at 3500 then 1 at side with the higher weight and axle weights, when I bought it I was informed it was 3850 I think it was upgraded from new as it has alot of extras fitted i.e. Aircon on roof
Mine are 3500 from Fiat, 3850 by Geist Germany, and then back to 3500 when it was registered in the UK.
If it’s taxed as PLG then, in the absence of any further plates, it’s likely that the 3500kg one is the final one. If you sign up for the forum you can post pictures so members can comment further.
