Using the shower.
Maspalomas, Spain
Giottiline Toscan 74
Well, after my successful thread on the usage of the toilet and seeing all the very informative and useful information gathered and a nice does of British humour - you guys 'n' girls really are the best, I thought I would ask for your input on using the shower.
I do know how to shower myself and have successfully used the showers on cruise liners (which tend to be very small too) so that is not what I'm after, rather the use of hot water and/or cold - mixed? only hot at a reasonable temperature? How do you go about it?
Once again, thank you all for your valuable advice.
Short bursts rather than leave it running while you soap/shampoo. Ours restarts quite hot before quickly settling to the desired mix - so we have a flexible hose to point the hot blast away from delicate parts.
I have a small bungee that holds the mixer tap closed when not required - a response to hitting it with my elbow once too often whilst manoeuvring on other bathroom duties!
We've just had the slowest bathroom fitted in a single bathroom house. Ended up using the van as the bathroom. Now I'm not the slimmest person but have become quite adept at the van shower. Ours is small (6m PVC) but is a mixer tap. Lots of quick short bursts, minimal water used. Wife not so keen as she has long hair. All part of the fun 😁
Even with the mixer tap selected to full 'Hot' the first few seconds of water will be the cold water in the hot pipe from the boiler to the shower head.
We collect this water in a saucepan for use as the next morning's boiling water for coffee.
Not exactly use of shower but more water conservation.
Obviously as posts above, wet, stop, shampoo/soap, wash, rinse. Saves water and gas/electric. Same system as was used on our boat, so an easy learning curve.
I can also reccomend the following Radox products for motorhomes.
^ don't buy from Ocado, but the shower mooses allow you to only need the tiniest amount of water, you can cover yourself in moose with shower off then rinse off with the shower head.
This keeps water use to abosolute minimums, we can between us manage 5 days off grid on 100 l of water, with 1 shower a day each, (and washing up in that too).... so we averaging UNDER 10l a shower, probably 5l. We both can shower on a single heat of the tank.
Something like this is useful easier to manage water flow
https://www.ebay.co.uk/itm/18571780...pid=5339023013&customid=&toolid=10001&mkevt=1
I have fitted a small trigger operated shower head, similarly as used in a hairdressing salon, not a full blown shower head, bought off ebay for not much money.
We have both hot and cold mixer taps in our shower, which I can set to our required temperature but running the water until correctly set.
Then, as you are only releasing water when you press the trigger grip on the shower head, it is delivering water at your pre set temprature.
So, 1.Press grip for quick rinse down and let go to stop flow.
2. Lather up with no water flowing.
3.Press grip and rinse down.
Uses very little water. And delivers it at a constant temperature without the faff of switching on and off the mixture taps each time and wasting water whilst trying to re-regulate the temperature again.
Dead easy.
Photo of shower head in my advert in classifieds for our van.
Have the shower then the toilet ask for more tips
I think we can do 10 days doing the same.
Some of us have different shower heads, they increase pressure and save water. Your shower should be connected to a mixer tap, it’s the same thing as at home. So strip, wet yourself down, turn off water, lather up, water on and rinse it off. That’s it, no science required.
As mentioned, the hot water tank is tiny and only heated to around 70*c. This’ll be plenty for you to use as the mixer will control the temp. The cooler it is, the longer it lasts. On my system, if on hook up (EHU), you can run the heating element and the gas burner at the same time to speed up the process for hot water.
So I take it your shower mixer doesn’t have a micro switch?
Most have a micro switch so when you activate the mixer the pump comes on. If you’re then stopping the flow of water with your shower head you risk burning out the pump.
We find the trigger type showerhead ideal squeeze trigger set temperature release trigger (trigger can be locked on) quiet often don't turn taps off so temperature is already set,got ours off eBay nice quality think it may have been from china about £8
I have the same one as recommended in post #13 and it works great with my Shurflo pressure-switched pump.
if you have a submersible with micro switches , stopping the flow for a few minutes while you lather up wont burn out the pump ..
if concerned, a submersible pump system can be converted into a pressure system by fitting an inline Whale pressure switch, thereby negating the requirement for micro switches
