Ezio_Ipswich
- Apr 7, 2025
- 5
- 5
- Starfire Autocruise
We've just purchased a 2nd hand motorhome, first registered in 2005. (Autocruise Starfire).
It has roof bars installed, and fixed steps up at the rear end.
But a local motorhome dealer basically laughed when I mentioned the possibility of me using the roof bars - he said that in motorhomes that old, the structure would be weakened and it would be unwise to load the roof in any way. [Presumably, for fear of causing a leak which then - most likely - limit the life of the entire van].
Okay, so three questions:
1. Is this common / good advice?
2. If I can't use the roofbars, there doesn't seem a lot of point having the steps. Is it easy / worthwhile removing the steps, and will it be easy to fill in the residual bolt/screw holes once I've removed the steps?
3. Is a rear-mounted storage box of some sort possible or, again, is the structure of the vehicle so weakened after 20+ years that fixing anything heavy to that too would be too risky?
It currently has a cycle rack fitted, and I'm now even nervous about using that given the dire warning from the dealer.
