A number of people have experienced BCM issues resulting in the Headlamps coming on and draining the battery because they could not switch them off. Guess, best way to switch them off is disconnecting the battery neg lead. If you connected a memory saver to the obd2 port and powered it with the leisure battery, would the headlights try and draw a current through the obd2 port and blow a fuse.
