USB Plug for Nextbase Dash Cam (5 Viewers)
MichaelT
3,954
8,311
Colchester
Carthago I 143 LE
Since 2016
Looking to wire my nextbase dash cam in. I've installed a USB socket for the SAT nav so thought I'd plug in there rather than direct to a piggy back fuse.
Currently it has a cigarette plug on so thought I'd try just changing to a USB plug so looking for one I can wire myself.
Jun 27, 2021
350
1,144
Lincolnshire, UK
PVC
Seasoned
If you read the installation instructions carefully you should see that Nextbase do not recommend using a usb socket for power. I think it is because 12v is needed as opposed to the 5v available at a usb feed.
43,811
53,188
Just buy a USB to USB lead.
Wiring a USB plug in place of a cig lighter plug will be near on impossible.
Just read the post above.
Cut the plug off and wire to a 12v supply.
Oct 27, 2022
95
219
Consort PVC
Every dashcam I've seen has a 5v usb power input
