USB issues
ShiftZZ
Dark Side of the Moon
I have 3 USB ports ad two are not working, tried to uninstall all the USB devices, but two ports still dont work..
Windows 10, suggestions are reisntall W10...
Thoughts?
Get a small Linux distro that you can boot from a USB stick. Just so you can check the ports are ok and that it really is a Windows issue.
My work laptop does funny things with USB devices when it's plugged in via a cheap inverter. Stuff not being detected and the mouse jumping all over the place.
Remove all USBs from the ports and try rebooting, sometimes it 'wakes' them up ...
+1. Use Device Manager to 'uninstall' them. Reboot, and it'll re scan for them and reload the drivers.
Bizarrely I have some devices that only work in certain USB ports, one example is my Garmin SatNav that only works in the LH side.
Mind you it’s not Windoz
Tried and failed...
Right Click Start (bottom left corner)
Left click "Device Manager"
Does anything there have a red cross or yellow triangle showing on it?
Scroll down to "Universal Serial Bus Controllers"
Do any have a red cross or yellow triangle?
If yes - Right click and "Uninstall device"
Confirm you want to uninstall it (Its just the drivers that will uninstall. When you reboot the system will detect it as a "new" piece of hardware, then look for an load the latest driver, and re-install it).
Close everything and Re-Boot.
If not - Right click each one in turn and
Select "Update driver". Select "Search Automatically..."
Do that for each one.
If any of them update, reboot.
If they still dont work, Right click start,
Left click "Event Viewer"
Select "Windows Logs"
Select "System"
Scroll through the "Errors" for the date and time you had the problem, double click the entry to read it and if it seems USB related then either copyy and paste the text into Google and search for an answer (or paste here).
NB There will be zillions of entries in the log and despite the best efforts of various foreigners of the Indian persuasion to tell you otherwise they are, mostly, just messages for techies to fault find and not the end of the world and do not need you to do anything / download anything at all.
Select "System"
Scroll through the "Errors" for the date and time you had the problem, double click the entry to read it and if it seems USB related then either cop(y) and paste the text into Google and search for an answer (or paste here).
Found a number of these...
A driver package which uses user-mode driver framework version 2.25.0 is being installed on device SWD\WPDBUSENUM\_??_USBSTOR#DISK&VEN_GENERIC&PROD_FLASH_DISK&REV_8.07#1EAD2DCB&0#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B}.
