AndyPK
- Oct 7, 2015
- 5,273
- 15,842
- Devon Firefly
- Motorhoming since 2015......
Hope your sorted now, probably a good idea to tell us the make and model of the boiler.
Edit : they can be a little confusing to start with, but get some manuels in English for all the appliances and learn how to use them. Most should be downloadable from internet.
Some may even be on here in resources section
In extremis, if it starts going out of control again and since you are not on EHU it will be running on gas so just turn off the boiler gas tap. The tap just for the boiler will be on its own or on a manifold with other gas appliance taps ( hob and fridge). It won't solve the problem (if there is one apart from not having completely filled the boiler with water) but it will stop the boiler from continuing to heat up.
Not sure about the 'quite warm light' in the garage but if the socket to which you refer is a 240v outlet ( you said you are not on EHU) so it won't work if you're not on EHU (unless you have an inverter fitted).
Although not familiar with your set up I think your water pump works on pressure so when you switch it on it starts pumping if it does not detect pressure. For example if you open a tap the pressure will drop and the pump will start in order to get the pressure back up and when the pressure is correct the pump stops. This is how it would work with your boiler, switch the pump on and the boiler will fill and the pump will keep pumping until its full then stop. Open a tap, or flush the toilet, run the shower and you will hear the pump start up again untill the pressure is back up. Hope this makes sense.
Shitfaced again no doubt!I've accidently had my C6 running on hot water with no water in the boiler for several hours. Had no problems or smells or noise from it.
Nope, my usual trick of leaving the timer on after a trip.Shitfaced again no doubt!
It will run on the leisure batteries, but maybe not for heating, just the fan ? was 12volts turned on ?
Whatever you do do not be afraid to ask any questions,we have all grotto start somewhere. That’s what this forum is about. There is no such thing as a stupid question.
It may help to know the make, mod el and year of the van.
When refilling with water after a drain down, put at least 40 litres in. Then turn on the pump and wait until it stops pumping. That's over 5 minutes in our current van. Then turn on each cold tap until it stops spitting, then each hot tap. Once the pump stops again, turn on the water heater.
Almost.....
Fill the water tank, open a hot tap and run until the flow from the tap is smooth without spluttering.
At this point the tank has no air and is full of water. Turn off the hot tap and turn on the boiler if needed now.
When you turn on the cold taps do one at a time until all taps, Inc shower, run smoothly
As above...you need water in the boiler to be able to heat up....these boilers run hot...a smell of overheating would be detected rather than burning.....make regular checks on van and if in doubt or signs of smoke call 999...better to be safe than sorry..
A smell of burning is an accepted reason to call for help.....
By filling the boiler with cold water should reduce the overheating smell....Stay safe..remain positive...
BTW, HKF, don’t forget the Easter subscription sale starts tomorrow at 8am (9am where you are, I guess….?)
HKF I'm assuming your MH is a Benimar Europe 740, as in your avatar. What year is it?
HKF Not much help unless you fancy a drive out, we are about 2.5 hours away from you in Surmur. Happy to help and take a look at your heating problems if you can get here. We are on a nice Camping Car Park spot, right by the river. Here until Tuesday morning.
It would also give you the chance to get used to the motorhome while having some help near by.
autorouter It might be the same one I posted just before you? Great minds !
Our Truma still sawells ‘hot’ when on gas water boost. No smoke though. I guess that’s about burning off production lubricants etc
OK anyway you could send me the main pages you think you most need according to the pictures? Whatsapp would be good, do you have it?Thank you so much. So, when I fill the water tank, I need to leave the pump on until it stops making a noise before I switch the hot water on? Is that right, please?
Unfortunately all the manuals are in French and I don't speak French. Don't hammer me for this, please. I'm on the verge of selling the van as it is, as it just seems too complicated and too much of a responsibility for me at the moment. I'm trying hard to get to grips with it but it's things lie this that are just too much. I'm out of my depth
I also have Viber. You send all this on my mobile phone and I'll make the translation on an email. Pm on its way with mobile number
Obviously you're posting on here, so you have a computer.
If no printer to scan then, the only thing I see is to use the camera of the computer. Open the manual facing the cam and take all needed pics. Ask your missus to help you. Then send them to me
tibou150@aliceadsl.fr
Not all at the same time.. My computer will die!
Also there are sites you can use to upload your pics, and then you can create a link for me to download them
