- Feb 5, 2024
- 545
- 872
- Etrusco CV540 DB
- On and off for about 30 years
I am currently installing a Fogstar 300Ah battery and matching mains 50A charger. I am also fitting a new Renogy combined B2B/MPPT unit to replace both the current Renogy 20A MPPT controller and the Schaudt B2B. I am also fitting a Renogy shunt and upgrading the current 1000W Renogy Inverter to the 3000W model, so there will be some bits for sale soon!
The reason for the question is that due to some space constraints I could do with getting the charger bolted into position before getting everything else wired up so I won't be connecting it to the battery just yet. It will be mounted vertically and I want the fan which is fitted in one end of the unit to work in the same direction as the natural bottom to top convection airflow rather than working against it.
I therefore asked Fogstar what I thought was a simple question - which way does the fan work - does it blow air out or suck air in. If it blows out I will put the fan at the top and if it sucks air in I will put the fan at the bottom. I tried powering it up with no battery connection, but the fan does not operate - I suspect it is thermostatically controlled to only run when needed.
Unfortunately despite much back and forth with Fogstar support I have not got an answer to this - the best they could suggest was plug it in and observe the airflow which I had already tried.
So, does anyone have one of these critters and can tell me whether its fan blows out or sucks in?
