Upgrade sound system
BaileyAutograph 74-4
Hi , has anyone upgraded the speakers our stereo system in Peugeot boxer cab ie motor home
If so what is best to go for , thanks in advance.
I changed the front speaker for JBL ones which were recommended. Fairly simple job to fit in cab doors. Several vids on YouTube.
I replaced the door speakers with COAX speakers made by a british company called Vibe. 180W. You will also need the Fiat to speaker adapter cable depending on the age of your MH, mine original speakers had a special plug that needed an adapter to change them to the small and larger spade connectors for the Vibe speakers. Lots of mounting holes in the speaker frame but none matched mine, so just adapted the aperture in the door panel to fit.
I just stuck a powered sub woofer in. Makes all the difference.
