Up Plated - garage load capacity
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Hi all - after any guidance please. We have a 2015 Adria A Class and the previous owner had it up plated with full VB air suspension which now has +1000kg of payload. The rear garage has the original sticker stating 150kg loading capacity. Does anybody know if this can be exceeded following the up plating? Many thanks in advance 👍
South Lincolnshire
Rapido 7065+
Broken most bits now
Very unlikely to be honest. The hab area beyond the original chassis is quite often cantilevered off the back so the 150kg limit could be driven by this. If you look under your van to see if you can see any extra supports to the back end off the chassis extensions then you may be ok to add more weight but Adria are the only ones that can really advise you
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Thanks! I guess I can just load up the main hab area of the van then, if needed.
South Lincolnshire
Rapido 7065+
Sometimes a towbar mounted carrier can help but the towbar manufacturer must clearly state what additional vertical load the installation is capable of carrying. Towbars aren't usually designed for heavy vertical loads but some may have a reasonable capacity.
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
Might be possible to get the support extensions beefed up/added to? I have always wondered about the strength of the garage (I put a electric motorbike in mine), If you look underneath it doesn't look like much supporting that overhang at all!
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Thanks, it does also have a tow bar installed.
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Actually the GVM was up plated to 4800kg, not 4500kg. Just checked the SV Tech paperwork.
Emmit
Cornwall
Pilote Explorateur
Jan.2014
Once at Apple Campers in Wellington, Somerset, (well recommended BTW) I saw the repairs necessary to repair an A Class garage that had been overladen/overweighed.
Emma (joint owner) told me in would cost the owner about 2 thou. to repair.
tonka
Cannock, Staffs
A class Burstner 800
Since 2000
As above I would not have thought so.
Would imagine its more about the floor structure and strength.
I have seen garages rate at 150kg, 250 kg (mine) and the biggest vans at 350kg.
Be aware to check the rear axle load limit, as sometimes uplates can increase the payload but only give a small increase to the rear axle. (y)
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Thanks, up plated paperwork is; Axle 1: 2200kg Axle 2: 2750kg
Jim
Ringleader
Sutton on Sea, UK
Adria Panel Van.
Since 1988
It is likely to be a structural umbrella, ie a known weak point, so if it fails, they are safe knowing that they told you. Less likely it may be the rear axle is already close to the limit. Have you weighed it?
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Thanks Jim - no haven’t weighed the van as I would think we are fine within the axle limits due to the up plating, rear axle now has a limit of 2750kg. We do monitor what we put in the garage, but thought I’d ask the question in case we carry additional “stuff!” In that case we will just load the hab area!
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
So! Adria U.K. have already responded (within 30 mins!) here is their response, I have asked for clarification:
As long as the MTPLM and the individual axle weights are not exceeded, and load in the motorhome is suitably distributed, there isn't a specific weight limit for the garage.
Jim
Ringleader
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Between the wheels is best. Most Garages, including yours are only really designed for light bulky items, like push bikes..
Problem is, the garage has become a most popular must-have and can be seen in vans that are just not suited to such storage. In some light vans you'll find 80% of the useful storage is now 4feet behind the rear axle; it's plain crazy.
IMO It's not even useful storage. In a garage, most stuff has to be junked on top of other stuff. For every tidy garage out there you'll see ten junk lockers where people have to remove half a ton of crap to find that tent peg.
Barnard Castle, UK
Concorde Concerto
Garages are great for storing bicycles, safe from prying eyes and the wind/rain.
I’ve seen small lockers with junk stuffed in too, you don’t have to keep loads in a garage.
To me it’s like saying” Let’s buy a small house with hardly any storage then it won’t look a mess”
If your the type of of person with a big garage crammed full of junk and can’t find anything then you will change to a smaller Motorhome with no garage and have small lockers full of junk can’t find things.
Cambridgeshire, UK
Pilote 740FGJ
Since 1986
Hymer do offer extra weight capacity in the garage when ordering a new MH, I can’t see why Adria wouldn’t offer a beefed up solution
T
TOAD on Tour
Lincolnshire
VW Grand California
Since 2020
Here’s Adria UK’s clarification, seems I can load more than 150kg if within the payload;
Adria Mobil applies that sticker as it is the simplest way of bringing to customers' attention to respect all actual payloads of their motorhome.
In some cases, loading more than 150kg in the garage of a motorhome could be the majority of the motorhome's total payload.
Kind regards,
Team Adria
