Unidentified machine in motorhome
Northampton, UK
autotrail tracker
As of today, 23/8/22 minus a few weeks! ( deposit paid, awaiting collection)
Good Afternoon
This might be a simple thing for anyone with an ounce of technical knowledge…I’m a few grams short of an ounce so I ask for assistance.
Our recently bought van has this piece of equipment installed above and between the cab seats. It has a drop down screen. There is also a small remote in the dashboard recess, which I assume is associated with this machine.
I am thinking it might be a DVD player? What is required to make it work?
You may recall my TV questions which in the end we took the tv out.
It might actually be nice to have use of a did player if use of it is easy enough.
Appreciate your thoughts!
Phil in Northampton
The dvd may be part of the radio/ head unit. Also check cupboards for any Freeview digital TV boxes. In the early days of digital / Freeview they often fitted a set top box.
Thanks for your response…
Can only see this, which I thought was to do with the tv.
Autotrail by any chance ??
I suspect someone has removed the digibox for the TV channels. Check out the radio and see if it has a cd slot and maybe the DVD logo.
Omniview is the rear view camera.
‘08 Autotrail Tracker
If you Google the number on the remote ...... RM-RK241
It brings up a few results Inc this one...
Hope this helps (y)
Here's a link for the manual of the remote control, maybe that will point you in the correct decision.
Couldn’t fathom anything from that, sorry.
Phil in Northampton
On my AT it’s the original tv, reverse camera, DVD player. I have exactly the same in the cupboard as you. I only use it for the reverse camera now.
Have you powered it up and popped into reverse. Can be done without engine running.
Blow me down! We have a reversing camera!
Eureka!
Next need to get a dvd to try that!
Sue says does it make the tea as well!
Thanks a lot!
Phil in Northampton
