Tyre Pressures
Flash514OVE
Flash514
Hi, my 6m Ford Transit Flash514 has the 16" alloys, 235/65R16C tyres. What pressure might people be putting in their tyres? Inside the door the Ford sticker says 51psi front, 61psi rear. Seems a lot, is that what others here are doing?
:welco:
That's quite low for a Motorhome, by the size looks like you have standard commercial tyres so best to contact the tyre manufacturer and give them your axle weights.
I run Toyo Observe Van 225/75/16 with the front axle at 1930kg & Rear axle at 2300 kg, tyre pressures are 56 psi front & 69 psi rear.
Thanks, so maybe my 61 on the rear isn't too much after all. Thanks, realised I should post this to the Chauson area too
I use 50/60psi on my transit feels about right....
Not a Transit but take your pick on ours…… 🤷‍♂️
Continental Vanco 215/70R 15 CP109. Front 1750kgs Rear 1900kgs GVW 3500kgs
Ducato Van Sticker on door pillar......F 72.5psi (5bar) R 79.8psi (5.5bar).
Converters User Manual (Sunlight).....F 69psi ((4.75bar) R 79.8psi (5.5bar).
Tyresafe UK website (not sure if that’s the proper name for it).....F 63psi (4.36bar) R 80psi (5.5bar).
Continental Tyre Chart.....F 54.4psi (3.75bar....much lower than the three above) R 72.5 (5bar).
Running at 62 front and 72 rear.
