tyre pressure caps (27 Viewers)
Apr 16, 2024
9
8
Burstner 745
Can anyone recommend (or otherwise) tyre pressure caps that transmit to a receiver in the motorhome? Are they actually any good?
Sep 26, 2013
4,263
5,294
Market Rasen
Self Build
Since 2003
Lots of people use Tyrepal sensors, I did have them on then sold them to a Funster as they leaked a bit and then you have to remove them to put air into the tyre.
I had then on rubber valves stems which is why I could not get them tight enough, Tyrepal recommends using them on steel valves.
1,194
2,683
Northern Ireland.
Adria Compact SC.
Since 2017
Tyrepal. I have used a set for three years. No leaks (steel valve stems). I change the batteries once per year and have had no issues. I wouldn’t be without them now. Great product.
Reactions: POH
Zigisla
2,639
3,204
Gosport, Hants
Sunlight A72
Getting better month by month.
I used tyre pal on my steel valves, but found I had a snag with 2 tyres loosing pressure quickly; removed tyre pal and this stopped. I also found the batteries need replacing a lot. So now cap with normal caps and check the good ol fashioned way.
941
2,765
Nantwitch Cheshire
A Class N+B Flair
25years
Tyre pal but I have steel valves I’ve been told it’s law in Germany over 3.5 ton? Had them over 20years now on my second set much better quality.
funflair
20,156
33,671
Guisborough
MORELO palace
since 2012
You may well be right there Brian as the tyre pressure monitoring that used to be part of the optional IVECO driver safety package is now standard, the rest of the package is the same price though :LOL:
4,681
10,420
South Lincolnshire
Rapido 7065+
Broken most bits now
Cheapo Chinese ones have been faultless in nearly 5 years use, originally at 80psi but now run around 65psi for comfort. One change in batteries after 3 years required.
611
1,265
Rapido
Tyrepal, work great on steel valves. Mine has the solar receiver, just keep it out of direct sunlight….
POH
May 29, 2018
1,251
952
Pilote 740c
5 years
enark , Solar panel sunlight don't they go together !! mine sits on the dash where it gets some sunlight.
81
133
Norwich, UK
Consort Oslo coming
We are expecting our first campervan in July 2024. This will be our first so we’re new!
enark Why do you have to keep it out of direct sunlight?. It’s a small solar panel isn’t it?
3,948
11,194
PVC
1995-2004 & 2017》
Have had Tyre Pals on my rubber valves for 6 yrs now.... no leaks at all..
Can I suggest if you can't them tight enough it is because you need to change the VERY small 'O' seals in the Tyre Pal unit.. and then tighten up finger tight...They wont leak!! I change mine every time the battery's get changed... Annually!!!
