Very close to getting 4 new tyres for my MH. My current tyres load index is 116 but the new cross climates that I want come in two sizes 116 and 118. Should I go for the 118 ? which are a little bit more expensive.
But they tend to have more ply layers in the tyres, making them heavier and more stiff, offsetting the benefit of lower pressure.Usually higher load index can carry same load at lower pressure
I'd argue that that's engineered into the tyre.Always wise to have a load margin 10% over the max axle rating.
The only manufacturer recommendation I've seen is to run camper tyres.Recommended on motorhomes when using van tyres as you are always running with max load.
