You have to make sure the door is fully closed at both the top and the bottom every time it is shut. Just pushing only on the top will likely leave the bottom unlocked? Push both top and bottom and heat it clock, then it will operate correctly.. it's a knack that you have to get used to with this door mechanism...I have been asked if anyone has had this problem for a friend of mine. Make unknown but a 73 reg model motorhome. It falls off whichever way she opens it. Once shut i assume the magnet strip holds it in place.
Yeah the silicone helped with that now clicks with a gentle push and we had a tin handy for spraying the cassette!You have to make sure the door is fully closed at both the top and the bottom every time it is shut. Just pushing only on the top will likely leave the bottom unlocked? Push both top and bottom and heat it clock, then it will operate correctly.. it's a knack that you have to get used to with this door mechanism...
