The 12v TV in our van a 24" LED TV L24FE13 has dreadful audio and I want to 'cure' it by fitting an external speaker, probably passive wired.
Can anyone recommend a good speaker?
How's the creative using AUX?Used to use these
Amazon product ASIN B00544XKK4
but changed to this a year or so ago.
Creative Stage Air
Creative Stage Air is a compact, under-monitor soundbar for computer that can also be connected wirelessly through Bluetooth with up to 6 hours of battery life.uk.creative.com
Both very good.
We've got ours connected via a stereo audio 3.5mm jack plug to the headphone output from the TV (Ferguson 24" - same as Cello by a different name) and powered by a USB cable from a USB output on our Manhattan SX Freesat box however have also previously powered it from a USB output on the TV.How's the creative using AUX?
I have a Majority Atlas but it hums when the aux cable is plugged in. I can just get the volume high enough without hearing it too much but looking for an alternative.
I have the Majority Atlas connected about the same as you connect thisWe've got ours connected via a stereo audio 3.5mm jack plug to the headphone output from the TV (Ferguson 24" - same as Cello by a different name) and powered by a USB cable from a USB output on our Manhattan SX Freesat box however have also previously powered it from a USB output on the TV.
The soundbar also has a built in battery that lasts (at least) 4 hours hours.
You can also connect to it using Bluetooth however not tried that in earnest yet.
We have the volume turned up to near maximum on the soundbar and adjust the volume on the TV using it's remote.
No perceptible hum or crackling from the soundbar.
If you are thinking about getting one the best price I found at the time was direct from Creative (as per link above) however they are now selling via Amazon with a 10% discount bringing it down to £26.99!
Amazon product ASIN B07HXCLM54
I've used Creative stuff (in desktop pc's) for many years and always found them excellent hence the reason I went for this soundbar.
