Turn off inverter while at home
Autotrail V-Line 635
We go away every two weeks for two or three days and also drive it once a week whilst at home.
Should I turn off the inverter when not in use or plug into shore power?
thank you
Mine's wired with an isolater so easily turned off. We only turn it on to use it.
In your case I can only suggest trying leaving it on and keeping an eye on the voltage. If you have solar that might be enough, even in winter. If it starts to get near 12 volts plug into EHU.
We only ever turn ours when needed, there is always a draw on the batteries when the unit is on, and the larger the inverter the more the draw, even with "eco" modes etc.
So I would turn it off - we have always had remote switching to make it convenient.
AdrianChen thank you
DBK thanks. We have 260w solar . No isolator but I can switch it off via bluetooth
It wasn't so much the drain on the battery (300ah lithium) it was constantly running it vs on/off and which was better/worse for it.
I think its better off being off when not in use, although I do start ours up every couple of weeks to warm it up and perhaps run the fan. I don't have any real science behind doing that though - It just lets me have a look round the van (in storage) on the "Dog Cam", and check it's temp/humidity. We do have remote access though.
We do leave the main battery switch on, so the capacitors etc are kept live on the unit (Multiplus II), that way we don't have to restart from dead which in an ideal world would mean restarting using a resistor to soften the inrush. I think this really only matters if the inverter is much above 1600-2000w though.
Electronics are generally aways best left on, it's the turning on and off which risks damage.
My point is the inverter will still be drawing a current when switched off. Some part of the electronics stays awake listening for the Bluetooth command to fire up again.
How much this current is seems to vary between makes but if you have lots of Ah you should be fine.
All electronic items have a life based on hours powered up. Some components deteriorate even just over time, such as capacitors.
Why leave it powered on unless its needed? Its a waste of operating life, energy and potential noise (fan) and pollution (fuel).
Im not green but cannot get my head around leaving anything turned on unless its needed.
Pedant, Yessss!
Tony
Not sure what the Multiplus draws when left connected but switched off, would imagine its next to nothing since it doesnt use bluetooth - the draw with inverter on without load is 13w - this can be reduced as low as 3w using search mode but I just switch it off - During the summer the Solar would easily cover the draw, but I think it's better off in the batteries!
You don’t run a car engine if you are not using it, so why leave anything on that draws power when not required, we have a Victron 12/2000/80 inverter charger with remote access as we have a permanent wi fi but if you use the Bluetooth current is drawn. If you turn the inverter off on the inverter itself no current is used as the Bluetooth/wi fi side is off.
Thank you
I am leaning towards turning it off. Last night the battery was showing 89% and this morning 82%. Apart from the Multiplus (Victron Energy Multiplus 12/2000/80-32 230 VE.Bus) I have nothing (that I know of) that is drawing anything from the battery. There is a 1.5mm cable from the leisure battery to the Multiplus to the vehicle battery to trickle charge it.
I thought to leave it tonight, check in the morning and if it is lower again then repeat with the Multiplus off to see the results.
There is a dongle with the Multiplus that provides info on its state via Bluetooth.
Thank you
Well yours uses 11w per hour (3-4 on search mode), to keep the maths simple for me thats 20amps + per day - the trickle charge will also be permanently on with the multiplus, so that will be pushing a couple of amps at the starter battery I guess.
Right now our solar (550w) is barely producing anything since the cloud cover is 100%. Yesterday 200wh ie 15ah. The system including Victron Cerbo etc, trickle to the starter and the MIFI charging uses around 14ah per day.
So if I left the multiplus on I would be using 35ah per day, less the 15 from the solar input, and my batteries would decline around 5%SOC. At the moment we just about balance, but with a smidge of sun we'll go back up.
My 2,000 watt inverter on remote standby draws 0.1 AH according to my shunt so 2.4 amps per day.
I have 230 watts of solar and 230AH of Lifepo4.
I don't turn my inverter off.
Isn't that basically turned off though? as in if you plug something into the mains it wont't have power until you take it out of standby.
That's great!
I'm quoting the Victron numbers for the model the OP uses, but assuming it's left on in normal mode rather than AES or Search mode which use less. I guess in Search mode at 3w it would be 0.25ah ish. 6ah per day.
You have an efficient unit, all of the Mastervolt/Dometic/Weaco and now Victron units we have had used more than 0.1ah on standby/ no-load but switched on. Our current one at 3w (on search) is pretty good I thought. Trouble is with ours is if I forget and leave a few things plugged in they periodically turn it back to full power.....
@all thank you
Unfortunately I have no idea what 'search mode' is or does. I have looked on the Fogstar app and don't see any mode options. Same with standby, I can't see how to do that from the app.
thank you
Not finished all my electrics yet but I do intend to switch my Multiplus 3000 off when not in use by of, I mean turn the 12v supply to it off.
I have a 4 way isolator switch in line with it, position 1 connects a 10 ohm 25w resistor to the input to charge the capacitors then position 2 connects 12v direct. As we occasionally visit daughter in Thailand for 6 weeks I don't really loads of stuff powered up when we are away.
Solar will be disconnected when parked on the drive so the batteries won't be left at 100%
I have an Ablemail to connect that will take care of starter battery charging for months from the Lithium even without solar.
Some items, especially power supplies and similar devices, also have a life based on the number of on/off cycles. This is a real effect which is reflected in the long-term reliability statistics. So the optimum life is a compromise between total powered hours and number of on/off cycles.
Yes I turn it off and on via the remote display not the inverter on/off.
It uses less in 'remote' standby than if it is turned on but with no load.
Not so.
You beat me to it.
As an example of the principle, diesel engines have a much greater ‘running’ reliability than they have a ‘starting’ reliability. It’s the reason why standby diesel generators (on power stations, for example) are regularly started (to give confidence that they will be available when called upon).
Ian
Same as we do actually now I think about it, maybe I should investigate turning it right off when it is in storage shed as we have a total of around 1 amp per hour drain but not sure how much of that will be attributed to the inverter, ours is a Buttner combi inverter charger.
thank you
On my Victron Connect app the only modes I have are:
Not sure what I am missing - thanks
Yes if I wasn't such a lazy git I would get on and copy your system - we always switched the main battery system off on the boats, but there was also a "maintained" circuit left on for the bilge pumps. I don't really like leaving it all on for weeks at a time.
Because the install was done in a bit of a rush, I might next spring relocate a few bits, and actually get round to putting in a 35mm feed for the B2B, so maybe then.......
The ablemail does work well we have it on the higher setting, and it does keep the cab battery above the sulphation level - Different to others because it switches off at 12.8v. I have a setting on the Load output of one of the solar controllers, linked to SW2 with settings so when the Leisure battery hits 14.2v (and goes into absorption) the Ablemail turns on to 9s on and 1s off for one hour, then it will drop back to the 10s on and 15s off. Bit like taking the van for a hours drive and probably unnecessary!
thank you
I think you need a mk3 usb dongle to get to the settings in Connect, which is different to the Bluetooth dongle for reporting. Alternatively there are some dip switches on the bottom of the unit that can be used one of which will turn on search mode, but since I'm not that familiar with your unit I would suggest the manual would give better info than me!
Having a quick look on connect in demo mode sw3 is the one - Demo mode is handy to play with these things - Its in the main menu of Connect.
The draw on the multiplus is minimal when switched off. Easily covered by solar so far even on dull wet days.
Unless it is in search mode it is 1.4 amps that is 34 ah over 24 hours going to need a huge amount of solar to cover that at this time of year. AES mode it is about 1 amp so 24ah/24 hours.
The total solar output for the last 5 days from my 350watts is a grand total of 23ah.
It seemed to be coping fine when I checked a few days ago. From memory the battery was sitting at 98% after 9 days with Multiplus turned off at the switch. As you know I am no expert, it was sitting at around 300ah on a 289ah battery when we parked up, but even so I calculate that’s a reduction of about 26ah over the nine days (280x0.98+(309-289)). Currently we are in Madrid (20 degrees plus) so I can’t look. I’ll have a good look when we get back see what the battery is sitting at.
