Truma valve jammed open - help! On the road in Scotland
Benimar Mileo 313
We’ve come to a campsite in Galloway this evening and added water to our tank and turned on the pump only to have all the water run out of the underside of the van - of course, I’d not closed the Truma valve! So out came the dinette table and I found the blue valve on the anti-frost system. I’d dumped all the water from the system in December and left the valve open but I now find that I can’t shut the valve. I’m frightened to force it. I’d already had the Truma air heater on for at least half an hour, so I don’t understand why I couldn’t turn the valve and press the frost button in. I can’t turn on our water pump as the system will just dump all the water, so it looks like we’ve a night of running back and forward to the loos. I wish we’d not parked so scenically and parked closer to the buildings!
Does anyone know where I will find a Truma specialist in southern Scotland? Any ideas about getting the valve unjammed? It’s facing north-south instead of east west as it should be. Thanks.
If the temp of the water going through the valve is below 4c it’ll keep opening, you may need to run your heating for a while to warm up things.
Mine stuck open once, keep closing it and manually opening it, the seals are probably dry.
Warm it up properly and all should be well. 👍
Can u put the heating on with no water in the boiler, I ask because that would be handy to know in the future. I have a 2002 hymer🤔
Depending where your valve is relative to the heater ½ hour is probably nowhere near long enough.
If the valve has got cold the air around it will warm fairly quickly but the body of the valve will take a lot longer.
Give it an hour or two then try again.
  • Informative
Reactions: f6c
The valve won’t turn at all! The space where it’s set up was already very warm. I don’t understand how it could have been too cold. To be able to move the valve. If I turn it too hard to the right, I’m concerned that I’ll snap the valve - stupid blue plastic 😡
However, I’ll try again before bed time. We’re really snug in the van, so hopefully the valve will have decided to cooperate!
Can you put a bung or cork in the outlet under the van, it's normally 10mm internal dia pipe.
Or double the outlet over and tie or wire in position?
Interesting that you should mention this - the water gushes out from the underside of the van - no pipes involved whatsoever. We only found this when we drained the van down before Christmas and haven’t got around to getting it looked at. We only bought the motorhome in November and are still getting to grips with the whole thing.
  • IMG_9342.mov
    32.2 MB
Boil a kettle.
Soak a tea cloth in hot water then wrap it round the valve for 10 minutes then see if it closes.
If it closes wrap a towel round it to insulate it.
That no look right, looks like the outlet pipe is missing from the valve and the water is running out inside the van and finding a way out.
I'm wondering if the outlet pipe has been torn off on a rock or kerb and it's damaged the valve.
Something I'd missed, if you can't physically turn the valve (90 degrees clockwise I think), theres something other than low temp at play. I think that if its just cold, you can turn it but the button won't stay in. Maybe if there is no pipe on the outlet, something has got up there to block it? If access is ok, maybe take it out to check?
Should be able to turn it either way even when cold, like you say button won't stay in.
Just to make you feel good they are around £120.
Mine comes out of the bottom of the van like that, no sign of a pipe.
You say it only happens when you’re pump is on, I thought the dump valve would dump water without the pump being on are you sure you haven’t got a burst or lose pipe.
Depends on where the water tank is, the dump valve should only dump the contents of the water heater, so if you turn the pump on more water will come out, but in some cases it might cause a siphon and contunue to empty the water out if your tank as well, even without the pump running.
Yep our Globecar Shine siphons the tank empty when the truma drain opens 😒
Get a couple of hot water bottles, and pack around the valve.
We keep two hot water bottles on board for exactly this reason.
Should flow straight out the pipe then, not like in that video where it looks like it's running out through various joints in the floor.
if you look closer, at about 60% of the way through the video, i think you can briefly see a round pipe exiting the floor and the waterfall effect is being caused by the water from that pipe dropping onto the vehicle skirt, making it look worse that it is .....
Go and buy a baby hot water bottle and sit it on top of the valve! The temps in Scotland are too low for a reset without!
Alex fae Perth
