Truma SDC12 solar controller Bluetooth dongle
Dreamer D55
First Camper 1970
Have just changed camper van and new one has a solar panel with Truma SDC12 controller. There is reference in the manual to a Bluetooth dongle as an option and there is a connector on it labelled Bluetooth.
But I can’t find a dongle that is compatible - Truma don’t appear to make one and others I have seen don’t state that they would be compatible with this controller.
Are these things standard, compatible with all controllers, or do I need a specific model?
Hi, did you find a Dongle to fit the Truma SDC12 Controller as I would be interested to make mine Bluetooth much appreciate if you can help. Thank you
The Bluetooth dongle you are looking for is called a BT01. Got mine from Sunshine Solar, about £25
just plug it into the SDC12 OR 25 and download the app. Gives you the voltage of the battery and shows the charging current. Also shows the charging history. Useful little tool. https://www.sunshinesolar.co.uk/Item/BT10
