Truma issue leading to electrical drama.
Hymer B668 (2017)
newbie
Here's the story of my day / evening.
Fairly new motorhome owner, our motorhome is on our drive during lockdown.
My 4yo daughter wanted to do a sleepover in the motorhome on the driveway tonight, nice change of scenery.
I popped out this morning to turn the heating on, Truma combi system using GasLow tanks. The boiler wouldn't fire up, E 122 H (will spin up a thread on this later!). Tried a few resets through the day, no joy. This evening, as part of troubleshooting, I went to do a "hard reset" - disconnected the leisure battery feed to the EBL and reconnected.
The problem is when I re-connected it, nothing worked. I fiddled with some switches, checked engine side was ok and grabbed the multimeter.
Feed from battery was fine.
Voltage at main fuse was fine.
Voltage at power input at back of EBL was fine.
All EBL fuses are fine.
But nothing worked, it was cold and dark and trying to use the multimeter and hold a torch was challenging enough, then it started raining.
I went inside to research the issue, read EBL the instruction manual, found a place to get the EBL repaired if it came to that, searched the forums. I assumed because I didn't have everything powered down when it was disconnected, there was some kind of power surge blowing an internal fuse.
Came to terms with the fact that I will now need to get the EBL fixed before i can get the original Truma issue looked at.
Told my daughter we couldn't do the sleepover tonight, got the kids to bed.
Sat down on the sofa, and it came to me...
"I wonder if the main control panel isn't just a display of the tanks and batteries, I wonder if it's a power switch"
Went outside, pressed it, everything came on (except the heating)
What a bloody idiot!
Now to figure out the Truma issue.... the sleepover will happen tomorrow night, helped along with a fan heater.
You may find the Truma also works now. If I shut down the power in the wrong order my Truma iNet box generates a message which is sent to my phone saying loss of 12V power. Whilst you may not have an iNet it suggests to me that the system doesn’t draw all its power from the same circuit.
Unfortunately having the same issue... Have you had good experiences with iNet? It was something I was considering.
Spent all weekend trying to solve our error codes😳😱🤷‍♀️
tried everything, looked on this site for past post on this and followed every advise, resets ect, watched utube vids but no, still not working, now showing W407h, but checked every fuse.
Sorry dong want to take thread but IV heard these combi6e can be nitemares!
I will follow thread to see how you get on
I like the iNet, I can lie in bed and turn the heating up. I can control the hot water or heating when out for the day and have it warm and cosy when I get home. At present the motorhome is in storage and I can not visit it, but I can check the voltage of the leisure battery. OK I can’t do much if there was a problem with the battery but it is reassuring to know that it is fine.
Have you tried this video. You do know there’s 2 fuses on the Truma 6e ?
I love the i net system too.
E122H is a gas supply fault code. If you have a Truma Secumotion/Drive-Safe system then you may need to reset the 2 buttons, one on the regulator and one on the pipe from the bottle to the regulator. They both trip off when the pressure drops e.g. when you turn the cylinder off.
Thanks, we only found one fuse under the lid of truma but will look for another today as I have seen another illustration showing 2 but so far can only see one
Will let you know 👍
We only found one fuse?
Will let you know 👍
The second one can be very difficult to get at. It is hidden under the main cover further down the unit. It is a slow acting 240V 10A one and prone to blowing. I am not sure that Truma consider this to be a user serviceable area but I have changed it successfully. Make sure the mains power is disconnected.
knowing the famous W407H means that there is a fuel disconnect (for me usually when I unhook the EHU before pulling away - or I have heating/hot water on gas and turn the gas off.), why does the Truma 6e CP show "no information available , contact support"?
Its an easy fix or am I missing something?
