Truma help
1ten
Help.
I’ve just filled up the van water system as we are going away and the overflow from the hot water outlet is constantly dripping a bit of research seems to show this is a small valve in the plastic elbow that stops the hot water over pressurising.
I don’t think I have a chance of buying a replacement now. Any good ideas how to fix it?
andy63
south shields
None
since 1990
If it is as you suspect its a pressure relief valve dripping id run the boiler up and see if it gets worse or stops it , if you havent already done that...
you might get away with using it if its only a drip... until you can replace the valve if it continues to leak..
Andy
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
May well take up when the boiler is hot, you're okay as long as it remains a drip.
1ten
I tried running the boiler and it is a constant drip. It seems to stop once the boiler is off for a while.
It looks like we will have to eat out all of the time as we won’t be able to wash up.
I was thinking of taking it off and try cleaning it.
The van is only 6 months old so I’m sure the dealer will happily swap the valve, just a shame it will involve a 200 mile round trip
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
thats not a presure relief valve its an air admitance valve to sop the cylinder collapsing when you draw on it also called anti vac valve
Lenny HB
On the coast in West Sussex
Carthago Compactline
Take the T piece out and soak it in hot white vinegar as often if can be a calcium build up in the valve. New valve is about a tenner a lot cheaper than a 200 mile drive.
Ismbardbrunel
Bolton
Rapido 963F
Off and on for a few yrs
Calcium build up in a six month old van....?
1ten
I am not disagreeing as I don’t know but I can’t find that mentioned in the paperwork from Truma. The other pipe connected to it is the hot water draw off and the pipe that the water is dripping from goes straight out of the floor of the van. If that is what it is whether is the pressure relief valve and outlet that is mentioned in the Truam instructions as the only other outlet that runs out side is the frost protection.
1ten
Why not, have to decale our kettle every few weeks, depends how hard the water is.
We live in a very hard water area and given the size of the valve that could be the case.
Lenny HB
It is actually to allow air to escape when filling from empty Truma refer to it as an "aeration valve". When drawing off hot water the hot water is replaced with cold water coming in so the tank is always full.
wasp
Warsop
None gone caravannin
Has it got a little clever on it , have you tried flicking it up and down, that sometimes cures it, usually it's a bit of grit in the valve. It's not often they fail when they are that new, but, then again :xThumb::xThumb::xThumb:
1ten
Thanks for all the help and options. I have tried it this morning and it seems fine.
It’s the first time I have ever filled the boiler after drain down so it could well be that that has caused it. We have hot water without the drip so all good and I will keep an eye on it and see what happens.
Renalt burstner
they often drip when you refill all that holds it closed is the water presure
