I've tried hot water, but this error keeps coming up. We have gas and I've tried the reset button, by holding down and it flashes green. Any ideas please.
Thanks, nearly a full bottle and the hob is working fine.Press the reset button again after 15 minutes to clear the fault. Code is lack of gas, check your supply.
Thanks, what is the rotary button?If the error is not flashing try tapping the rotary button a couple of times to reset it , if it is flashing leave it 15 minutes with the control still turned on and when it stops flashing tap the control button as described ( After you have checked the gas supply is ok , according to Truma information)
The black button on the control display panel. (it can also be used to illuminate the display)Thanks, what is the rotary button?
Tried the reset button, the regulator is only a year old, the hob works fine. Its this typeHave you tried the rest button on the boiler it's under the plastic cover.
If it is lack of gas the regulator have probably failed, common fault, the hob will work but not enough flow for the boiler.
Same. Our dealer was useless when we had no gas so hurriedly popped in on a Friday afternoon (we were AirBNBing our house so only parked a mile away)When I had this code the problem was definitely the boiler reset which is not just a case of pressing the reset button.
Try the attached instructions I got which are more precise
Fingers crossed it works.
James
