Truma heating system (1 Viewer)
freddiekrugersdog
18
Cleethorpes
Van Conversion
1 month
Hi. . . . just a couple of questions relating to the Truma heating system. I have uploaded an image of the controls for the heater under the seat mid cabin. and my question is . . . . what is the source for this heat and when is it best to use it (other than when it cold) I mean . . . . Hooked up / not hooked up / driving? . . . . My wife is temperature sensitive and using this heating will help me get out more!
I have instructions for water heater which sits adjacent and the gas heater but not for this one!
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
That is not a Truma heater. It's fed with hot water from the engine cooling system while you drive. When you are on site it will do nothing.
D.
F
freddiekrugersdog
18
Cleethorpes
Van Conversion
1 month
Thanks D that explains a lot . . . . and why I have no instructions. . . . . I have another question !
This image shows the gas heater on board . . . . is this the only source of heat that goes around the ducting to various areas ?
two
Aug 4, 2011
4,914
4,590
West Midlands
A-Class Fiat
Yes, but you have the benefit of not having to run the blower, which can use quite a bit of current.
F
freddiekrugersdog
18
Cleethorpes
Van Conversion
1 month
Marvelous. . . . . knowledge is everything! . . . . and just one more question . . . .!
This image shows a little rocker switch located on the right hand side of the pelmet of the window mid cabin . . . . I don't have the baldiest clue what its for . . . .any ideas?
Jul 13, 2008
3,780
4,643
Low profile
Outside light?
F
freddiekrugersdog
18
Cleethorpes
Van Conversion
1 month
Boringfrog . . . . uummm! not sure . . . .only lights on that side (off side) are the running lights . . .will double check them next time out . . . .Hardwick Hall next Thursday
