Truma heater dumping water (1 Viewer)
Sep 8, 2016
115
96
France
Hobby 750
Since 2010
Hi this is the first time we have been out in freezing conditions in our Chasson flash 20. 2014 model We have noticed that when we turn on the pump it is dumping water underneath. I am presuming/hoping this is the dump valve on the water heater. Can anyone tell me where this is located and how to close it please? Thanks
Mar 14, 2020
702
578
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
I would first look for where the water comes out on the van. It should be above that on the inside. It’s often on the floor near the boiler or near the pump. I don’t have your version of van. Hopefully someone will be a long soon. Good luck
Cush
125BEER
1,160
3,061
PLYMOUTH
BENIMAR MILEO 282
Since 09 2018
Frost protection valve....Its the in-line valve/switch....It will be located near the boiler unit could be black with blue reset button.Check your manual it should let you know location.
Cheers🍻
golly
2,018
70,239
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
There are two types of frost protect valve, don't know which type your van has, but it will be near the boiler as stated previously, here are the two types of valve
385839371_redknob.jpg.f237e540cd523bfe00f9af7b9a832b34.jpg hope that helps
Tombola
5,000
16,159
Merseyside
Rapido 8094DF
Since 2004
I had a chausson flash 5 and it was in the lower part of the wardrobe floor.
If it's the old type valve you will be able to keep it in the up / close position with a peg or similar.
If its the new type with the blue button you can use some tape or wedge it.
This is the new version
Nov 4, 2011
6,040
40,680
Uk
125BEER
1,160
3,061
PLYMOUTH
BENIMAR MILEO 282
Since 09 2018
This forum is great for help and advice but remember to look at supplied manuals occasionally maybe with a beer or wine...👍
Cheers👍
9
97243
Cheers👍
I have exactly the same problem at the moment, but I can't see a dump valve that looks like anything mentioned here. I will just go and have a read of the very badly written general handbook, which of course is only in French, but hopefully there will be a picture.
125BEER
1,160
3,061
PLYMOUTH
BENIMAR MILEO 282
Since 09 2018
As some other Funster has said the dump pipe on the underside will not be far from the actual boiler.Trace that back...
Is it a Truma...?
Cheers🍻
9
97243
Found it hidden under a drawer ! It is an old fashioned toggle valve. All okay now (y)
