If the temperature get down to around three degrees check that the valve has actually dumped.
Just reset it now and then when we have a cold night check to see if it has worked, at least you will know if it is still doing it’s job.We've drained it down manually
We have also had replies from the manufacturer and the dealer. The manufacturer says they are investigating (Adria) and the dealer (Geoff Cox) says they will keep up pressure on the manufacturer. It is out of warranty so they could just wash their hands
Thanks for keeping us updated with the outcome. Really pleased you got it sorted. Sounds like a real find does Mill Garage. £54 for an hour's labour! Twice that up here.
@Puddleduck - where is Mill Garage and are they motorhome dealers? Sounds like they know what they are doing and a good find. We need recommendations like this. I understand people have been similarly impressed with Adventure Leisure at Tebay.
Strangely, I was looking at our Whale pump and, concerned that it might be faulty, am going to buy a replacement for taking with us.
Buy a couple of connectors & a scrap of pipe from an accessory shop. Much easier to practice than have it described. It really is very easy to do. If you have room to do it of course .It seems that quite a few people carry spare water pumps and I can see why. If your pump fails one of the main features of a mobile home/campervan is useless.
I don't think I will have a problem fitting the pump if required so long as I can fathom out the connectors. On an earlier post, someone confirmed that the new model pump is a direct fit. Just unclip the tubes, unclick the electrical connector and replace with the new pump and reconnect.
Ah well, that's the theory. Dare say, when sitting in Spain, in freezing rain, no water for the kettle or heating I'll find some problem!
