Truma fault
fiat ducato swift
Hi I’m sure it a mark 4 version.have not had the van long but noticed that the heater only worked if thermostat was full up.
The control switch did not have any lights on obviously no water or heating.
On checking full 12 volts at unit 2 pines at control have 5 volts removed main pc cover, fault PC board burnt out . My question is has anyone had same symptoms and replacing the board fixed this ,or is the PC board the result of a further fault ( at £280 quid for the board would not like to plug it in and blow it )
Many thank in advance of advice
Ian
It might be worth speaking to Truma and explain your fault. They're usually very helpful.
