Morning all. Boiler lights are all on and the right colour. But boiler not firing. Works fine on gas. Think need to reset the boiler. Can't remember do I leave on to reset?
Have exactly same problem, no fault codes but no water heating on electric (Rapido 691 2010 vintage) am going to grovel around on the floor under the sink to see if it's an overheat reset, after that I hope someone can enlighten both of us?Morning all. Boiler lights are all on and the right colour. But boiler not firing. Works fine on gas. Think need to reset the boiler. Can't remember do I leave on to reset?
I think there is also a Reset Button there too !!!If you take the plastic cover off covering the PCB on the boiler there are less on the PCB that flash when there is a fault the flash sequence should determine the fault. Need to look up the fault codes on line.
There is, but it’s tiny.I think there is also a Reset Button there too !!!
