TerryL
Been on EHU but now off grid. Up to now everything appeared to be working okay on gas and/or electric. But last night I got a red light so assumed gas had run out, although the fridge was okay, and changed the bottle. Reset but now the heating (on gas only) only works if I set it to both heating and water. On heating only I get the normal green light but the heating doesn't fire up. Switch to both and I also get the orange light, again normal, and the heating fires up. Switch back and the heating shuts down, not instantly but in accordance with it's normal routine. Hob and fridge work normally so I'm happy it's not the supply. The control panel is a Nordelektronica and otherwise seems to be working fine in every other respect; I have considered resetting it by disconnection, wait 30 secs then reconnect, which some years ago did clear another unrelated fault.
I've checked around for any damaged or broken connections but that just about exhausts my knowledge so am I looking at a replacement PSB (?) board. I'm happy to try a Control Panel reset, just worried I'll muck up something else. As it stands I still have heating so at the moment it's not a catastrophe.
Any gas expert with an opinion please?
