Truma boiler
bailey approach 750
I’m getting hot water but not any blow heating ? Green light and red flashing light on panel on boiler ….what’s wrong?
:HelloThere:w2f
What model of Truma do you have?
The red flashing light will probably give a code of short / long flashes which helps to identify the fault. Is it, and assuming it is, what is the flashing sequence?
:HelloThere:w2f
It’s a Truma 4e it flashes red 8 times ….how do you find out what the flashing sequence means ?
Thanks for replying
:hiya: Truma error codes
Thanks for replying
The flashes should be a combination of short and long.
The file for the code sequence is in the Resources section but I think you don't get access to that area until you pay the members subscription. Best money you'll spend in relation to motorhome ownership given the wealth of experience and advice on here.:xThumb:
Just on a side note... Are you plugged in to mains? I just want to know if your hot water is actually via gas or whether it's via electric.
Is there any blown air coming out of the vents and have you been able to count the red LED fault code flashes on the combi boiler electronics board ?
