Truma boiler controls (5 Viewers)
Feb 22, 2011
10,517
22,077
Newcastle under Lyme
Hymer B544 A Class
Since 2015
If I switch on my Truma boiler for 40c hot water it frequently doesn't fire up.
But I've found if I switch it to 60c for a few minutes first it works faultlessly even if I turn it back to 40c.
I'm guessing it's a poor connection in the switch or gummed up contacts ?
Blown air functions work as they should
Does anyone know if the switch can be dismanteled and cleaned up please ?
This is the switch
TIA
Dec 2, 2019
4,701
10,461
South Lincolnshire
Rapido 7065+
Broken most bits now
You can see the finger contacts behind the dial when you remove the switch A clean with a cotton stick and some acetone or contact cleaner may help
Apr 22, 2018
7,320
13,431
Herts.
Adria Coral lowline
I think on the 40 setting the temperature has to drop very low before the boiler will fire.
