Aerialmark
Hi, last October my wife and myself were away when we noticed water coming from under the bed and found we had a water leak on the cold water pipe. Anyway fast forward to last week I decided to replace the pipe’s behind the water tank which meant I had to remove it. I have now refitted the tank after replacing all the pies behind the tank including the hot water pipes and cleaned the tank out. The trouble I’m now having is that the cold water is spluttering all the time and the hot water seems to be not as strong as before even though I’ve done what I usually do to get the air out. Also there is a lot of vibration when you open the taps which I presume is due to the air in the system. Is there any way of getting this out or have I missed something else that should be done ? Also when replacing cold water pipes I didn’t put this back as I thought it was just a pipe stop on an unused pipe. Am I right in thinking that or is it something to do with getting rid of trapped air ? Thanks in advance.
