or better still let his partner have a holiday in the MH on his/her own!Leave your partner at home
Isn’t that increasing payload? OP =Fill the tyres with helium (or better still, hydrogen, which you could use as a fuel).
Freeze your water because ice is obviously lighter than liquid water.
Wear airtex underwear.
Remove one wheel nut from each wheel.
There’s still quite a few haven’t read the title correctly. .Isn’t that increasing payload? OP =
Top (tongue in cheek) Tips to reduce payload
That would be no good if you crap in your van toilet and/or put the hair clippings in the bin in the vanMake sure you have a good crap before setting off, and also get your hair cut.
I depends how you read it and whether you are thinking like a muppet or not!There’s still quite a few haven’t read the title correctly. .
I believe the OP was looking for humorous suggestions so reading the title literally is about as humorous as it getsI depends how you read it and whether you are thinking like a muppet or not!
Basing it on the OP's comments the idea is to ''reduce payload' of what he is adding to the MH, ie to lessen the payload of his chattels so he can get down and stay within the MAM (ie it is overweigh at present) or be able to take more of what he wants but stay within the MAM , thus the suggestions made would seem to help with that ... although some are very questionable to say the least!
However if you read it another way and think it means to reduce the available payload of the MH that doesn't make sense ... so IMV you would be a muppet if you thought that as no-one would want to actively reduce the actual available carrying capacity of the MH for the sake of it.
And also to let the clutch out.Drive with the windows open to get rid of any excess air.
We will have to go out for a ride sometime!Towards the end of a long cycling ride and the hilly bit (The Fred Whitton) - A fellow cyclist and friend of mine once ate all his food that he was carrying in his saddle bag. To 'lose a bit of weight for the climb" he said
Better still remove the chassis.Remove your rear coil springs. Your van will be tilting backwards whilst driving, but when you get to the site you wont need leveling ramps.Weight saved- springs and ramps
Can tell you've never been married!Take the scooter out of the MH garage and make the wife ride it behind you - saves money on buying a trailer for it.
coats, shoes, towels, makeup, food stuff, none of which can possibly be used while away.please feel free to add further suggestions ....
Always iron your clothes so there is no in-crease of weight ....
Only carry forks with three prongs, you should remove unnecessary prongs
Only carry right handed screwdrivers, if you need a left handed screwdriver then you could always use a right handed screwdriver anti clockwise
Wardrobes full of clothes increase the vehicles overall weight, so wear several layers of clothing while driving instead of storing them in the wardrobe
Only take grated cheese or cheese with holes in as they weigh less than 'solid' cheese, pound for pound ...
Weight decreases the higher you go, so always drive uphill where possible
