They're all the same, just biggerI'm talking MH ones, not flipping commercial ones!
In theory maybe but not in practice.They're all the same, just bigger
When have you ever seen anything that's made for a Motorhome that's been designed properly?I think you're thinking about the limitations of peltier cool boxes there
Vapour compression systems can easily reach -30°c if designed properly. One chamber I worked on was set to minus 80°c
I agree , telly's up so high makes your neck ache, swivel drivers and passengers seats that don't line up/ swivel enough with side benches, so it's not comfortable to relax and put your feet up, on our Chausson we had if you put a 13 amp plug on socket and fully swivelled drivers seat you could hit this mains plugWhen have you ever seen anything that's made for a Motorhome that's been designed properly?
They can obviously run off different power sources so if you have a lot of dull days with very little solar input the gas will keep the fridge going when the batteries could struggle. 3 way ones also cool to a lower temperature in very hot weather and hold it better.
Some compressor fridges only cool to X amount below the ambient temperature so not as good in very hot weather and believe it or not some don't like it when the inside of the MH/PVC is cold so you have to turn the heating on! Also we found that compressor ones can be noisy which is a pain overnight.
I have never been a spirit level "level" sort of guy.. if van is level enuf to be fairly comfortable to live in its good enuf and I have never had any issues with any of my absorption 3 way fridges.Having never had one I’m curious about how level you have to be for it work, not an issue with compressor fridges.
Can you explain the theory of this please. Are you saying that a bottle of max salt water will be a lower temperature than without the salt or just that it will maintain a lower temperature for longer if filled with salt water.We have a cold box refrigerator thing we put a load of salt in bottles till it won't dezolve any more then thay go in the freezer
And then thay go in the fridge and cooler box
Works fine for us
Bill
Quite a few of us using them, it makes a big difference and the recovery time after opening the door is really improved but it does put up the gas consumption.Not heard anybody mention the use of the internal fan. I find it works well on my fridge. It is battery operated. I need to to wire it up to 12v when I get a minute.
Just had a thought Lenny...Here is mine.
Don't see the point, my fan is blowing onto the cooling fins, I did a few experiments and found it worked best that way round.Just had a thought Lenny...
If you put an LDR on the base of T1 to ground the fan will go off when the door opens. Simple mod with no wiring
Different fan to mine.I have been running an internal fan in our fridge for a few years now to even the temperature around the fridge compartment.
Like the look of yours.
Where did you purchase it from please?
I used two cooling fans from a PC, mount them on the edge of the vent cavity.It’s times like this I wish we were good at DIY and could fit those fans to aid cooling as our 3 way fridge is not the same side as our awning. Please don’t tell me how easy it is as I’ve read the threads numerous times on how easy it is and I don’t agree. It’s only easy to you lot who find it easy! Once it’s out of warranty I think we’ll pay someone, you can’t always park against a nice hedge.
I did see someone at a show once who had a mini awning structure stuck with stickers to their van, it didn’t quite look homemade, but a bit like the sort of thing you might see on an old fashioned pram. Unfortunately they were never in their van when we passed to ask them where they got it.
This is what we did a few years back when the thermometer reached 49°. In direct sun mind, Keep the fridge nice and cool.View attachment 642944
Fridge was struggling when in France last week, I remembered something I’d read about fans to help so did a temporary fix with a rechargeable fan to try and help, it definitely made a difference, going to get some permanent fans sorted now we are back home.
I Like that can you do that to a house freezer on 2 sides and top ?I put 50mm PIR insulation around our Dometic.View attachment 644261
You can get condensation on the skin doing that though if it's not air tight.I Like that can you do that to a house freezer on 2 sides and top ?
I did add Aluminium tape around the gaps when the fridge was in.You can get condensation on the skin doing that though if it's not air tight.
it will maintain a lower temperature for longer if filled with salt water, compared with ice.Can you explain the theory of this please. Are you saying that a bottle of max salt water will be a lower temperature than without the salt or just that it will maintain a lower temperature for longer if filled with salt water.
Ice will stay at 0°c for hours though while it melts, all the time absorbing heat.it will maintain a lower temperature for longer if filled with salt water, compared with ice.
Liquid water holds heat/cold about twice as well as solid ice. So if you can find a way to keep the water liquid at -20C then it will 'hold more coldness' than the same weight of solid ice.
If you add salt to water it lowers the freezing point so it stays liquid at below zero, so that's a way to keep the water liquid.
If you want a really tech explanation, the heat energy required to heat/cool a kilogram of something by one degree C is called its 'Specific Heat Capacity'.
The specific heat capacity of liquid water is 4200J/kg/degC, and for solid ice it's 2093J/kg/degC. The salt changes the specific heat capacity, but not by very much.
In case you're wondering, water has a very high heat capacity compared to most easily available substances. It's difficult to find anything with a higher heat capacity than water.
Well someone decided salted caramel was a good idea so you never know.Mmmmmmm Gin and Tonic wi salty ice cubes... you MAY be on to a winner there.
And salt n chillie fae the Chinese carry out.Well someone decided salted caramel was a good idea so you never know.
