Tomtom Mydrive on android
swansea
Autosleeper Broadway
Since 2013
Don't know whether I'm being thick but I can't figure out how you plan/adjust a route using Tomtom Mydrive on my android tablet or phone. I can't get any answers on Google re using android either. I can get routes from A to B but I can't ad stops or drag onto different routes. Does anyone know how to do it please.
Have you tried using a different browser, some say use other browsers (not chrome), some say uninstall mydrive then reinstall .
Hi Fidge
I don't have an Android phone but an Apple one and based on the following which is what I would do can you do the following on your Android..
When I open the App a circle with 3 dots appears at the top left
Tap the 3 dots and select Plan Route
Lets Assume you want your Current position as the Start point Tap the second slot and insert your destination.
A route is created so now Tap the + at the right hand end of the Second box and a new box appears.
You now add another position here which could be your Stop point On Route.
The route now will show your On Route position as the destination. To change this Put your finger in the MIDDLE of the Third Box and you can move it up or down to where you want it on the Routes List and the Route will be replanned. You can move all Boxes this way.
You can Tap a position on the Map and Add it to the route or Tap one of your My Places and add to the route each will add a list of boxes at the top. You finalise the route by reordering the entries.
Hope this helps
Hi Fidge
Hope this helps
Thank you so much, I've been fiddling about for hours and have finally got it to do two.stops. I'm going to try and print your reply future reference.
Hi Fidge
Hope this helps
