Toilet Lever (17 Viewers)
Dec 8, 2022
373
826
bury st edmunds
Boxer Peugot 2001
newbie
Hi you lovely Sunday morning Guys,
I have realised over the past couple of weeks, as only had Renee for 5 wks now!
That the look is leaking onto the floor! Well, now the basin bit, that seems to be dry! It happens, when I open the lever, push it back, and a dripping of what looks like condensation water ( but maybe, that is me being hopeful here, and it is not Urine ! SHREIK!), that comes out of the lever on that motion of pulling it, and putting it back again.
So at present, I am away in the Derbyshire dales on a Bentley Rally, and stick some clothes under the lever, to stop it dripping onto the floor !
Please Please tell me this is not something too problematic or expensive, as Ive now spent my lives savings on Renee, not a lot left ! hahaha
Thank you not too difficult explanations either , Im a lady novice owner hahah
Caroline
So
Emmit
8,386
18,911
Cornwall
Pilote Explorateur
Jan.2014
It 'could' be that on a previous 'occasion' the slider was not quite completely shut or open.
In such circs. it is possible that 'liquid' can circumvent the seal and escape.
Take the cassette out and open the sliding mechanism and the hole and seal that it fits in. There may be 'something' (Heck, I don't think I've used so many inverted comma's in one post before?)
Make sure the seal is doing exactly that, ie. sealing.
Don't know your van, but, going back, they used to fit carpets in bathrooms.
If that's the case and the carpet has got wet with, 'something' mop it up best you can and then get some enzyme cleaner from a pet store. Puddle the area with the cleaner which will kill the bacteria and the smell.
Riverbankannie
11,054
64,267
Bristol
IH 630 RL PVC
Do you have a tip up basin in the washroom? The waste pipe behind can block and overflow.
Photos of your setup and where the “moisture”is would help.
Nanniemate
6,830
47,003
IH
The pipes can also perish or split and need replacing
May 15, 2022
881
2,586
Bavaria
Pilote P969D
Since 2012
Had a similar problem with mine, a drop or two of something ( didn't do a taste test) on the floor under the handle.....solved it by cleaning the seal each time I emptied the cassette....
