Toilet flush rubber split
Hampshire
Chausson 640 welcome
Since October 2019
The white rubber around the flush slider on our loo has split and fallen apart , is it easy enough to source a replacement and replace ?
Yes. If its the dual fush valve just isolate the water , twist the fitting out and replace the washer. Washers are a couple of pound from plumbers merchant
No it’s this piece , it sits above the flush handle (found between the legs :-) ) and although I’ve removed it doesn’t seem to have any definable use
