- Feb 13, 2025
- 146
- 135
- Don't own one yet
OK, so I am going over my electrical plan again, to make sure I haven't overlooked something or used a wrong-spec item.
So, I'm on the subject of battery protect.
If I were to use a D+ wire to ensure the dc-dc charger only operates when the ignition is on, couldn't I fall into the scenario that the ignition is on but not the engine and so, the starter battery could/would drain.
So then I saw a thing about fitting an oil pressure sensor, which, because it only has pressure if the engine is actually running, the dc-dc charger could be set to function only when there was oil pressure i.e., when the engine is actually running.
And then I remembered that I often over think things or generally complicate them.
So then I thought about connecting to the wire from the alternator, which should (I think) only be live if the alternator is charging the starter battery.
Is it OK to tap into the live from the alternator, to flip a relay thus enabling the dc-dc charger to function only when the engine is on, not when just the ignition is on?
