To all people with knowledge of MOT standards
Pilote Explorateur.
Since 2019
A raised manhole cover and a tree jumped out behind me when I was reversing and caused damage to my bike rack that is connected to a tow ball.
Rather than buying a new bike rack which grounds quite a lot, I'm thinking go building my own bike rack that fits to the chassis. I have the tools and knowhow but I don't know what an MOT tester looks for, and what he would consider as a MOT fail or advisory.
Has anyone got any info as to what is needed for such a bike rack.
I have seen some bike racks that extend out from the rear, I just wonder what are the MOT standards for such a thing.
Thanks for reading
Dave.
It would matter if it was unsafe other than on MOT day.
Well here in Spain it would need to be officially homologated by a competent engineer. So it's a no go from the start.
As Barrie has said ,if you are actually in spain with a spanish registered MH you've no chance .It has to be a homologated construction & additionally fitted by someone who is a 'professional'*
*that just means they have the right paperwork to supply the installation certificate ,not that they are actually any good
If you are UK based It would be the same as a towbar.
Security, condition, mounting points and lighting.
strictly speaking does that mean a fail if you have a towbar but not electrics mounted to it
No, the towbar won't restrict view of the lights but it will be a permanently fitted rack and requires lights and reflectors the same as a towbar fitted rack when mounted on the towball.
Not the same but if you have a towbar fitted with the 15 pin type plug it is part of the test. Older 7 pin are not apparently.
Maybe so but you asked if it would matter in an MOT, which obviously if it isn't on ,on the mot day it doesn't.
It's the same as strapping anything down on a vehicle , you are not going to see if it will pass an MOT every time.
Ok I maybe need to explain better.
What I want to do is make my own bike rack that will fit onto the rear of my motorhome, my question is would it pass an MOT.
I don't want to be stopped by DVSA or their European counterpart and be told it should be like this or like that or "what you've built is unsafe and needs to be removed before you can leave".
The flag on your status is Spanish, so are you in Spain? If you are then the question has been answered - i.e. NO.
It’s actually quite simple, google MOT testers manual and see for yourself, also google DVSA categorisation of defects.
The first is guidance for MOT testers and the second is guidance for roadside inspectors but the 2 documents ‘should’ support each other with the roadside one being more detailed carrying reasons for rejection, if it isn't in the list then you’re pretty much ok.
Assuming you’re in the UK that is?
Why not ask an MOT station? They should know the correct answer. They will be making the decision.
Thanks I'll do that when I back in the UK.
Thanks I'm going to look them up.
Google and YouTube can be one's best friends when doing something out of one's comfort zone.
If you’re building a demountable chassis attached bike rack, then if removed, it will not be subject to any MOT inspection as you’ll have removed before the test!
If not demountable and a vehicle newer than I think 2007/8 then you can’t make your own chassis mount, it needs to be proprietary and not home made!
It’s probably not legal if stopped and using a home made rack, but that was not your question, so i didn’t answer that part! 🤪
Yeah ok lol
That last line made me laugh.
I think I'll repair the lowball mounted carrier. The lowball needs a little heat to make it only slightly more vertical to enable the bike rack to be about 100mm higher, making it more likely to not ground.
Thanks for reading
Dave.
If it is NOT a towbar then it isn’t a testable item but it must conform to the Construction and Use regulations regarding overhang percentage behind the rear axle (no more than 60% of the wheelbase), sharp edges and lighting if appropriate.
Once fitted it also is a modification and should be declared to your insurance company.
Thanks, I think I'll just fix the bike rack as it's on the towbar.
Dave
We have a towbar which I fitted but haven't got around to sorting out the electrics yet. Mr MOT man asked if I could remove the ball before the MOT else it would have been a fail.
With the bar fitted but no ball he was more than happy without the electrics as technically it wasn't a towbar.
Not sure if he was right to do so but who am I to argue 👍
Something in the back of my mind believes, as from a few years ago, that is also the case in the UK.
I think towbars now have to be tested and fitted by a 'professional' . 🤔
I certainly wouldn't heat the towball enough to bend it, that's going to change the atomic structure of the steel and weaken it.
If it's the old style 'two bolts on to the bar' flange type ball just replace it.
If youre vehicle is pre 2012 then self build is acceptable.
Post 2012 towbars have to be type approved I suspect this will apply to chassis mounted product.
My best mate is an MOT tester and he tells me a lot of stuff is at the MOT testers discretion but the main thing for something like that is if it isn't fitted at the time of the test, it can't be tested, so take it off. My tow bar is detached when I take it in. Not there, can't be tested.
I MOT an off road motorbike for green laneing. No mirrors, no indicators. Always passes as because they are not there, cannot be tested and there are no switches or mounts for them either.
You would be suprised how slack some MOT standards are and others are tough. Eg motorcycle MOT, no rear reflector equals dangerous fail. Nail in the tyre, cannot fail it.
Here is a link to section 6 of the MOT testers manual that covers body and attachments.
https://www.gov.uk/guidance/mot-ins... all types,assess its strength and continuity.
I was just coming to say a modification of this type would be more likely to be an issue to the insurance company than to an MOT tester I would guess?
Unless it was a hack job that is obviously outside of the norms or patently unsafe. The both would have issue.
That's odd, because a car will fail for that.
