Tiny remote control
Milopoppy
Welcome 625 2014
Hi I recently purchased a Welcomec625 2014 and have found a tiny remote control on the shelf above the door by the control panel. Does anyone know what it's for ?
Picture at all?
It could be for the lighting system if it has a Sargent system on board?
Hi its also magnetic
google image search has it as a level indicator for gas cylinders
Gaslevel, level indicator for gas cylinders.
Gaslock's GASLEVEL® Universal Indicator is the perfect helper for camping, barbecuing, crafts, and for use on gas-powered outdoor heaters. It quickly indicates the filling level in 5 kg, 11 kg and 33 kg propane gas cylinders that are usual in the trade.
You just have to fix the GASLEVEL® indicator in a vertical position at different points of the cylinder, using the magnet that it has on the back.
Depending on the fill status of the container, the indicator light changes from red to green or vice versa.
If it is necessary to change the batteries, insert a thin knife into the small slot at the bottom end of the red cover. Here you can then carefully pry off the cover.
